mk2f fox coupe breaking plus many spares/upgrades
£ sent for the clocks
cheers
  • Replies 112
  • Views 10.7k
  • yorkshirevw
    yorkshirevw
    £5 plus postage
  • yorkshirevw
    yorkshirevw
    I can't confirm if it squeaks as I bought it to replace mine and never fitted it, it has a good resistor and comes as seen.
  • Heater motor received. Many thanks, as described, fair price and received quickly
Would you be willing to post the rear beam?
I would but it would be a fair cost, it's big and heavy.
would you be able to find out the weight of it?
thanks
thanks
Not accurately, I've only got bathroom scales.
PM;d
Alright bud.
im after the door water/wind seal retaining caps. The leading edge of the door casing has like a foot long rubber seal heals in place by 4 caps. I'm after all 8 if you have them. Poster to Lincoln. Please :)
james.
I might have them but they'll take some finding, I removed my strips when I sprayed the roof. Do you have a picture of them to send and I'll have a dig Friday.
Number 16 on here
Remember the part and knowing me I'll have kept them, I've just no idea where, I'll look tomorrow.
Should be 4 each side I'm after all of them but can do with 5. Just the caps I need.
If I find them you can have the lot.
Everyone Please Note
If I get the suspension off it's an 80/60 Kit
just noticed I miss typed the original post.
they are still attached to the car at the moment.
Rear beam is off , Non-ARB intact but with 23 years of surface rust, drums etc still on. Suspension currently still attached at the bottom.
Also rear side windows £5 each
On 16/07/2016 at 16:01, yorkshirevw said:
I have found some details on the GT head work, it has had the casting marks blended, the valves lapped, new stem seals, the valves are all good, one is new and it's been skimmed
price reduced to £150 for the head, £30 for the GT cam and pulley and £20 for the polished 6N cam cover.
do the front wings have any rust dents in ?
and you you have any way of getting them down the southwest  ?
one or two small dings in the wings, rust on the bottom edges and a little on the arch lip, I think the tops are just sooty, the paint appears intact.
They could be couriered down south but I cannot guess at a cost for this
Do you have any of the black plastic centre caps?
I've a set without bolt covers, think they are mint, £20
Not the ones I'm after I'm afraid. The ones that are literally just a centre cap
No, I've none of those.
I have found the ARB blocks, they look in good condition, just oily £20
hi do you still have the carpet as after the front and rear parts if you do how much posted to taunton
cheers
Edited by pavos
cheers
I've only the front section.
How much posted
Sent from my HTC One M9 using Tapatalk
