Vag com
What can you do with vag-com other than diagnostics
found out how to turn on and off the beeping when locking and unlocking but not much out there for a 6n2 gti
  • Views 762
On the 6N2 there is very little in the way of "options" you can activate/delete, it's only on 2005> that the "options" list gets better :)
Ok thanks
so with this polo it's just a case of turning the beep on and off and codes then
Basically yes, if you've got Xenon lights with the automatic range control, you use VCDS to align the headlight aim, if you replace the ABS unit, you can put that into service mode to correctly bleed the system,
Ok thanks
