What colour is this?
Hi See the 2 green stickies can someone tell me what colour this green is?
Says "GREEN" on the V5
Thanks for any help.
  • Views 726
In the boot there should be a sticker on it it will state all the codes for the car including the colour code. If you are unsure then take a picture of the sticker and someone will be able to confirm what the colour code is.
Sweet glad I saw this going to my dads tonight got the 1st MOT tomorrow in Mintlaw against your better advice sorry.
I will see if I can work it out from the sticker and take a photo like you say if I can't.
Thanks.
Had a look and its "Montana Green" when I looked up the code:  LB6Z.
Edited by lilsammy
Colour is....
Sweet, let me know how the MOT goes. If you need any help just give me a shout.
MOT failed but I expected that, it needs a few things:
- McPherson strut on one side has failed.
- Bulb holder needed for number plate light
- Number of emissions failures but the guys at the garage said this is because there are several leaks in the exhaust causing air to be drawn in and I will need to take the exaust off and refit / reseal it properly but theres nothing wrong with the actual exaust itself in terms of wear it looks new so probably just fitted badly by the last owner.
I have 10 days so the race is on!
