Poly Bushes (MK2F) 3D Printing
Hi this is a general question I was looking for something else on ebay the other week and I noticed someone selling what was clearly 3D printed bushes for a polo.
This is my first car never-mind first polo and I noticed that poly bushes do seem what I would consider expensive for some plastic with metal sleeves in them.
Has anyone had any experience with 3D printing there own or using 3D printed ones?
I have a 3D printer this is why I am mainly asking, I could print HIPS which would be extremely strong plastic or print ABS which would be slightly softer which is what the set I saw on ebay looked like.
I can see by the size of them they would literally cost pennies in filament material to print.
Thoughts, experiences?
EDIT: Looked into a bit more and no one has really publicly done it as far as I can see people have experimented but the problem is materials and getting something close to polyurethane, some people have printed them out of ABS to create molds to make poly ones but directly printing them seems a no no from what I can find.
Edited by lilsammy
  • Views 2.2k
The ones that look like plastic are actually nylon. They are a fair bit stiffer than Poly bushes and to be honest the front end of the Polo benefits better from the nylon ones. They are expensive, but they are a very worth while handling upgrade.
Hi I'd be interested if you made the moulds then did it. What sort of price where you thinking for a whole set? I think everyone on here would like a competitive priced set.
Edited by idontunderstand
not sure im still researching it at the moment I am looking for pour-able plastics like nylon for things like arb blocks to try first as they would be on of the easiest parts to swap out for testing plastic qualities.
This interesting because I thought of getting someone to print a spacer for the offside wing mirror. Those of us that are over six foot can not adjust the mirror on a Mk2 to a position that is ideal. The cable manual adjuster just doesn't go far enough so if the whole mirror was mounted a few millimeters out it would make all the difference. This way the plastic that touches on the window rubber could be integrated to make it look like a factory item. My son's work prints in ABS. In theory can other plastics be used? What sort of file do you need for printing? IGS?
I'm not sure 3d printing these is worthwhile really when they could be spun up in half an hour on a lathe.
3D printing is a very long drawn out process when you're printing solid objects like a suspension bush would need to be.  It would probably take most 3d printing machines a couple of days to do one bush. 3D printing (on an amateur level) really becomes invaluable when it is used to make complex shapes which don't need much strength to serve their purpose.
I dont mean to piss on your chips as I like it when people use initiative, but if you want to get creative and 3D print things for your polo then bushes might not be the best thing :smile:
Edited by Phataz1
Thats a great idea I have a lathe I can use at my dads :D would need to measure a stock one to match?
Drill centers and use metal sleeves?
Edited by lilsammy
