9N3 OEM fog lights?
Hi I am planning on buying this fog light set off ebay for my 9n3 polo.
http://www.ebay.ie/itm/VW-POLO-9N3-MK5-2006-2009-SPOT-FOG-LIGHTS-LAMPS-PAIR-SET-O-S-N-S-WIRING-KIT-/401167887960?hash=item5d67782e58:g:jrMAAOSwdzVXqb~c
My concern is with the wiring harness supplied and how will it be installed. I have seen some guides on the forum but they seem to have a different wiring harness than the one above.
The other thing I am confused about is whether or not I need to buy a different switch for the fog lights. I currently have the switch in the 2nd photo that only has the one logo of fog light but I have seen some with 2 fog light logos for the front and back so which one do I need or are they both the same?
Edited by MickOS34
  • Views 2.4k
Looking at that item, it has a relay that isn't required on the OEM setup, so I doubt if it will be a direct plug into your existing wiring connectors, You will also need the correct light switch that has the two positions for front only & front & rear
Oh ok thanks. I contacted the seller too about the installation instructions and he said it comes with none. I might just chance it to see how it goes unless someone could recommend a seller or site that sells a cheap set without the plastic grille
