They still turn up!
  • Replies 50
  • Views 5.2k
  • davidpant_teg
    davidpant_teg
    It runs! New cambelt fitted today. Carb now set up. Choke works properly and I sorted out the thermostatic fan by cleaning all the contacts in the fusebox. The spin off is that a number of the electri
  • davidpant_teg
    davidpant_teg
    Finished sorting the brakes out on Monday but then had to help a pal with his Peugeot as his rear suspension had collapsed. (a common problem, but then it's FRENCH! What can one expect?). He did help
  • davidpant_teg
    davidpant_teg
    Brake fluid change is on the list to be done. Gearbox and engine oil/filter already changed. Also Antifreeze changed as I fitted a new water pump when I replaced the cambelt. But thanks 1vw2many for t
