1993 Mk2F Polo Fox coupe 1.3 swap
Here I have a 1.3 fox coupe. Recently had an engine swap which needs finishing. All the hard works done and the engine turns over just will not fire. I haven't really had time. Everything is there. Bodywork is okay, lots of door dinks and there is corrosion on the bottom of the passenger door, I have 2 engines, the original 1.0 which I believe to be seized but I'm unsure and the 1.3 which resides in the car. The 1.3 has a piper cam and here is the forum post from the guy who sold it to me
http://www.clubpolo.co.uk/…/345919-polo-gt-engine-convers…/…
It needs 1 hose from the expansion tank to the water lines. The car comes with uprated speakers and the seats are all in good condition. I also have some msw mesh wheels pictured which I can throw in
Also has a brand new s/s exhaust from cat back (cat removed and only one rear back box, straight through otherwise)
The car has an mot until next June I believe, loads of spare parts, like a 5 speed and 4 speed gearboxes new cambelt and water pump and even a Haynes manual if you want it
Everything is there except what is mentioned, if you have any questions please ask
Needs a days work to get back on the road and running well
07919172516 please call or text with serious offers only. Needs to be trailered away. I'll try and clean it as well!
  • Views 618
  • kwijibo_coupe
    kwijibo_coupe
    Price seems a little high considering it doesn't run, needs finishing and trailered away. But your car your choice. Good luck with the sale/swap.
Needs a price please as per the forum rules :)
£800 without wheels, £1000 with wheels
