9N3 wire route from engine bay to cabin.
Can anyone recommend a good place to route a small wire through a 9n3 polo firewall. The only obvious place I can see is the unused hole for the hood cable on the passenger side but the insulation is fairly tough to get through.
  • Views 1.8k
See answer in your other post
For anyone needing to route a wire through the firewall I ended up going through the rear washer pipe which is located behind the abs pump on the passenger side.
