Mk2F Parts
Got all of these as part of a job lot and need to make some room, everything is collection only from East Yorkshire, just outside of Hull due to the size and awkwardness of the parts
Got 2 rear bumpers, believed to be off a breadvan, Average condition both have scuffs and are faded, one has a trailer socket fitted to it and the tow flap is held on by bluetack, £10 each
Trailer socket one
Mk2f bonnet in Primer, good condition with no dents, couple of scratches from storage but nothing deep, washer jets still attached £10
Mk2f Bonnet red, Good condtion but will need to be repainted, Few scratches and a couple of stonechips, also a couple of areas where dents have been filled, you can see this in the photo, better than it looks as it is quite dirty from storage £10
Breadvan rear glass, got an N/S and O/S with seals, good condition, stickers come free, slight over spray on both but will clean up, the other N/S has been painted, no seal, one side is green other side is primer, you could strip the paint of easily enough, and the other O/s is in good conditon but with no seal  £5 per glass
Back Box, probably no good as rattles when moves so the baffles are probably shot but otherwise is intact with its mount, £5 might be good to someone
Passenger front wing for a Mk2f, Rust in the usual places, scratches from storage but dent free and would clean up £10
2016-04-18%2016.34.05_zpsbl3meryp.jpg2016-04-18%2016.34.21_zpsbwse5ea4.jpg2016-04-18%2016.34.30_zpsas6nl1qh.jpg
Top strut brace never used £10
Rear Light for a breadvan N/S, Good condition no cracks, etching or crazing, needs a clean but the bulb holder is there with bulbs £10
Rear Light For a breadvan O/S Good condition with no cracks, etching or crazing, needs a clean, bulb holder and bulbs present £10
Rear Light for breadvan N/S Average conditon, has a small crack in it, primer overspray on it but will clean up, bulb holder and bulbs present £7
Rear Light for a breadvan O/S Average condition Small crack at the bottom and a little bit of crazing, again has some overspray but bulb holder is there £7
Inlet for an spi, not sure what size engine it came off but I reckon a 1.0, someone has started to polish it up £15
Could probably post the lights and the inlet for extra cost but that would be at your own risk!  would prefer collection
Also got loads of trim, sunvisors, grab handles, seatbelts, seatbelt covers, the black trim that goes on the b pillar on breadvans, rub strips, grey door cards, grey parcel shelf- can dig out an take pics if anyones interested
Edited by fossy97
  • Views 389
That's a shame if you were closer I would of taken a wing, the bumper, a rear light and the strut brace.
Bump Still got everything and more
