Key help
Has anyone changed the 6n2 key to a flip key is it possible or what do you have to do to change it
thanks
  • Replies 9
  • Views 891
Get the flip key blank cut to your original key profile, carefully remove the transponder chip from your original key and put it in the flip case :)
With the buttons work as well?
As I've got remote central locking
As long as its on the same frequency as your original key, then all you have to do is Syncronise the new fob to the car, I'll dig out the method
6N2 Matching a new additional key.doc
Aren't the circuit boards different in these keys if so where do I get them from or Vw only?
You'll need to get a fob with the circuit board in it, if you want the remote to work, you can't fit the inards from your original key into the flip fob. Normally plenty on ebay
Ok thanks for your help how do I find out the frequency of my key or car?
Yes that's the correct one in the link, good price :)
Got the key got it cut but can program it like you said before any ideas?
