Replacing TCA's - mk2
I've never replaced a set of TCA's before - has anyone got tips/advice? I have a Haynes manual but as we all know they can over-complicate things.
Thanks in advance!
  • Views 694
i would jack the whole front end up
arb off
undo the fixings , might need to hammer onto the old tca downwards to make it come out of the strut    inners on first , then ball joints , hook each end of the arb in , second end might need you to use your foot for leverage , then lower the car and the arb mounts should line up
check all the bolts once its on its wheels
poly/nylon bushes on the arb end are worth doing while its apart
Thanks Steve - currently doing what I can with limited budget, although once it has an MOT I will be more inclined to spend out on a few upgrades. I have a brand new pair of TCA's sitting on the shelf doing nothing :)
As above - no prisoners. ARB off and new arms on then fit arb into arms. Fit ARB to chassis last.
Edited by randombadger69
