6n2 non starter, warning lights dead
Please help! My daughters 1.0 mpi 6n2 broke down yesterday. It started stalling and then stopped all together. A few days ago the water temp gauge died, now the fuel gauge and all the warning lights are dead. The engine turns over but will not fire. I can still hear the fuel pump pressurising when I open the drivers door. Anyone got a clue where to start? She's got her driving test tomorrow and I would like to fix it for when (hopefully) she passes!
  • Views 893
Welcome to the Forum.
Unfortunately, there are several possible causes of this problem, but one 'common denominator' could be the ignition switch.
If you have access to a multimeter, it may pay to remove the cowl and check the output from the switch (I assume that you have already checked obvious connections and fuses?)
Regards
