1.9 TDI Sport?
Hi Everyone, Retiring to Portugal and looking for a decent little car to downsize too. I've been offered a 2008 Polo 1.9 TDI Sport? Guy says it's the sport version of the Golf engine, and pumps our 130 bhp standard. Also has better suspension, etc. I've seen it and it has 'bucket' type seats, and a six speed box. Other then that is looks like a really clean car, but nothing special. Any advice from anyone greatly appreciated as I'm new to VW, well my last one was an old 6V Beetle. Kick myself, wish I'd kept that one. LOL.
  • Views 935
They're a good car, a lot of fun, and not common in that spec (basically, it's a fabia vrs, but a vw). I drive a Seat ibiza in the same spec.
The weak spot is the power steering. Any sign of a fault light, be concerned and investigate further, preferably do a diagnostic check. The normal fault is the wheel angle sensor at the bottom of the steering column. They're £70 for the part, ideally you'd want the car up on a lift to change it, which makes the job easy.
Beware any electrical problems. And sign of a misfire (could be a £70 wiring loom that's DIYable, could equally be camshaft wear.
The top half of the cam belt cover just unclips, so no reason not to see how old the belt looks. A decent independent will charge about £300-350 to change the belt.
Front suspension does wear due to the weight of the engine. Yours is a later car, so there shouldn't be any need to replace the anti roll bar.
Boost hoses and the intercooler do perish and cause boost leaks, that's a bit of a "they all do it". You'll tell if it's boosting properly when you drive it.
Rear brake calipers can be prone to seizing.
Don't let this scare you off though, I love mine and if something happened to it, I'd buy another one tomorrow. I've done 50k miles in it in 2 years and not have any problems that I wouldn't call normal wear in a car it's age. They're not hard to work on, although the engine bay is a bit tight, and parts are cheap.
Thanks for the feedback. I've done a bit of research, also test drove the car, and we've decided to buy it. Rear discs had a bit of wear, so I'll check out the callipers once we get her him. Garage has given it a service, well oils and filters, and new pads on the front. We pick it up this afternoon.
