Software to read live sensor data and log?
Hi chaps, I'm looking for some software to read sensor data from the car and be able to log it for later review. I have tried a few OBDII programs but none like to connect to the car's ECU (probably because its not full OBDII) I am able to get VCDS lite to show live data but not log it and also it won't show everything unless it's activated and I can't justify 99 doll hairs right now. does anyone know of any software I could use to log data? obviously it'll have to be compatible with the Polo's halfway house way of doing things!
  • Views 1k
Thanks Nige, do you know if that one will let me read/log multiple modules at once also?
Like wheelspeed sensors from ABS module and RPM sensors from Engine module at the same time?
With the full version you can use the vagscope, to see individual sensor outputs like throttle position against manifold pressure, (Basic Measuring blocks)  I've not tried it to see if you can log/see the data from different modules at the same time though.
