Mk1 rhd conversion
Just curious as to how hard it would be to convert a mk1 to rhd. I would obviously need a different dash and steering rack, apart from that everything should be okay to carry over wouldn't it? Is there much welding involved in the bulkhead? Thanks
  • Views 1.2k
It would need pretty significant work to the bulkhead and probably the scuttle.
From looking at a LHD mk3 you'd need to move the mounts for the steering rack, modify the scuttle to accept the pedal box and master cylinder. Also maybe the mk1 is simpler but on the mk3 things like the steering cowling were LHD specific.
Mk1 Polos were available in RHD and still about so probably easier to by a restore a RHD example rather than modify a LHD example.
mk2 has most of the pressings /markings for the pedals etc ...steering column would need  cutting off and welding , no servo so wont be molded around it like the mk3
wiring is basic enough so shouldnt be the end of the world to mod it
if you can get the dash and rack id say go for it ...its a fairly basic car compared to most
Wipers will sweep leaving an annoying dirty wet arc (like early mk2 Golfs). Make sure you get matching arms with a RHD wiper mechanism if you plan to remedy this and fill the blank hole. The splines are different size on newer models.
LHD Speedo cable is shorter
LHD Accelerator Cable is shorter and feeds differently. Loom will need extending.
Choke cable(?) is longer so can reach RHD below dash cutout.
Mk1 polo wipers were all the wrong way round anyway.
I can see that now in the lovely banner picture above every 10 seconds!
