AFH Engine Mounts (Drivers side aluminum lower half)
Well, I sent some bit to get powder coated while I was away on holiday, including the the lower half of the driver side engine mount. See below picture....
And when I got home after fetching everything, i discovered it was missing. The coaters are looking for it, as is their blasting guys.....but I thought I  should start putting some feelers out there to see if I can get a replacement just in case. Clearly going to charge it back to the company, they lost it after all.
  • Views 275
I have this spare, I haven't got the steel part though, but the aluminium part I have is polished £15 p&p if it's any good to you
Got one Powdercoated silver
