Vauxhall Cavalier
Got a bit more stripped down this afternoon. Cam belt covers, belt, sprockets and water pump followed by the thermostat housing.
Annoyingly, one of the little bolts that hold the thermostat cover down cracked the lug that contains the threads when I wound it out. Hopefully a mate can repair it for me with his TIG set, if not I'll be trying to find another housing. Part no. 90220434 88-1  😞
The lower outer part of the cam belt cover is missing, as well as several of its metal clips. The "wanted" list begins!
Also required -
Cam belt,
Water pump
Gasket set
Thermostat
Crankshaft pulse sensor
All for 1.8 SE. Any help sourcing these bits would be most appreciated.
Edited by sleag40
  • Replies 513
  • Views 49.9k
  • Three days later it was done.
  • I was a little worried that my bodywork skills may be a little sub par, but the paint bloke had very little to do other than paint it.
  • That thing will be better than new when finished! Love this thread
A little more done today - the insides of the wings received a coat of epoxy mastic.
Back to the engine, first up all the wiring was removed
Then the inlet manifold came off.
This leaves me with a large amount of cleaning to get through, but due to a weekend away, it won't be getting done for a while!
Seriously cold/damp grimness this afternoon, but still managed to beat the urge to go home. Lots of messy clean ups to do, so I decided to let myself in gently with the starter motor and alternator bracket.
The starter motor will be painted satin black, and the alternator bracket will be getting a rub with a scotch pad to brighten it up a bit.
After ignoring it for a fair while, the horn is now ready to paint.
A cambelt, water pump, thermostat and gasket set are now on their way, and a mate has given me a crank pulse sensor. It's from  mk3 cavalier - it's plastic instead of metal, but fits the hole, and the plug is the same. I don't know if this will work - if anyone can advise me on this, I'd be most appreciative.
Mk3 one on the left.
Got a bit of time on the bead blaster today to clean up a few bits and pieces.
The flywheel cover got a bit of silver engine enamel before available time ran out.
I'll hopefully get the other bits painted some time this week.
Black bits painted in engine enamel.
Exhaust manifold was blasted yesterday, (cheers Dave!) and sprayed with high temperate paint at work this afternoon.
More freshening up of filthy stuff coming soon.
Procrastination took up most of the available time today. I did manage to get the alternator cleaned up though.
I'll be blasting and painting the fan, pulley and tensioner arm in the week to smarten them up a bit - the main body came up well enough to leave as is.  🙂
Edited by sleag40
More cleaning done over the last couple of days - first was the engine wiring loom.
Never knew that the injector plugs were yellow until now!
All the coolant hoses and hard pipe were then dismantled and given a thorough cleaning, they came up surprisingly well. I need to swap out a few corroded jubilee clips before they go back into service, the pipes were then reassembled so I don't forget how they go.
The starter motor was then given a couple of coats of engine enamel. I'll be using the same stuff on the engine block when I get round to cleaning all the crap off it.
More cleany/painty stuff to follow! :)
Finally got some paint on the horn. As you'd expect after being so rusted, it's severely pitted - but does look a lot better than it did.
The alternator bits have been blasted, painted and put back together. Looks pretty reasonable now.
Made a start on the inlet manifold + associated gubbins.
Got it all stripped down, now just need to pretty it up a bit. 🙂
Way colder than is bearable for long down at the shed this afternoon - an hour or so was enough for me. Inlet manifold relieved of 99% of its coating of muck.
I'll finish it off with some alloy wheel cleaner another time.
Finished cleaning, then reassembled the inlet manifold stuff. It looks a bit nicer than it did last week!
I also got the cam belt covers cleaned up ready to put back on - still on the hunt for the missing lower outer part.
I had a bit of a trial with petrol/diesel mix for cleaning the head/block. Its no better than neat petrol, but there's a free supply of it available to me at the moment.
Before I left, I cobbled up a blanking plate to stop crud falling into the engine now the dipstick/breather has been removed. There's gonna be a fair bit of muck flying about when I get stuck in to cleaning this thing!
You really do go all the way
I do - but not on a first date!  🙂
Managed to make a bit of progress cleaning up the lump this afternoon.
The plan is to get the top end satisfactorily clean and leave it as bare alloy. The bottom end will be done in black engine enamel. (still a long way to go until its all clean enough)  😞
Edited by sleag40
Time has been in short supply again this week, but I've still managed to get a few bits done.
Made a start bare metalling the block.
Smartened up the HT lead clips that bolt to the camshaft cover.
Breather pipe/dipstick tube, its bracket to the block as well as the dipstick itself have now been blasted and painted up.
In other news, I spotted another new wheel trim on ebay, having a spare one can only be a good thing. 🙂
You're going totally stock then dude! Refreshing to see a nice stock MK2 and not something lowered or made into an sri rep
Theres very few of this model left - I think preservation is the best plan for it.
All oil + paint now removed from the block.
Just needs the rust wire wheeling back to shiny metal and it can be painted. Probably gonna have to leave that until it warms up a bit though - far too cold to paint anything in there at the present time.   :(
Not had any time for this until this afternoon. The core plug that sits behind the starter motor looked a little suspect after I took the wire brush drill attachment to it. It was rust pitted much worse than the others, so it was ousted.
A full set was procured from ebay
And the dodgy one was replaced.
Hopefully I'll get this painted at the weekend.
Block now has 2 coats of engine enamel on it after a mammoth wire brush/cleaning session.
Should get the sump pan painted tomorrow, so I can start putting it back together next week hopefully.
The missing part of the cam belt cover plus the clips arrived this morning. Many thanks to Keith at Vauxhall Green Parts.
Sump pan now cleaned and painted.
Just waiting for a stat housing to arrive, and it can go back together. 🙂
Replacement thermostat housing arrived today thanks to a top bloke called John off mk2cav.com. I gave it a quick bath in petrol, then a cheeky bead blast to leave me with a ready to fit part. 🙂
Hopefully it won't be too long before the engine is reunited with all its parts.
I was hoping to get the motor built back up this afternoon, but thanks to good old ebay, the cam belt and water pump were wrong. The ebay fitment check is clearly not to be relied on.  😞
Although its tempting to clean and refit the old one, I'm gonna have to play water pump roulette again.
Edited by sleag40
Correct cam belt and water pump went on yesterday, alternator and some odds and sods went on today. I just need to remember to take my torque wrench with me next time, then I can finish the engine jobs off.
Managed to find a new manifold to downpipe gasket on ebay.
Then threw the remaining parts back on the lump.
Just needs the loom fitting, and the cambelt covers cleaning again, and it's ready to go back in when the time comes.  🙂
Edited by sleag40
class! excellent work as usual😎
Playing with scooter parts,
job hunting, and numerous other endeavours have all but stopped play on this. I did get a little bit of time for it today though, so made a start on the crusty fuel pump/filter arrangement.
One of the rubber mountings required a bit of grinding to get it off, but other than that it all came apart nicely. I have a new fuel filter to go on, and the pump cleaned up well, the crusty bits will be blasted clean and painted up at some point.
Its kind of satisfying to have made a start on this assembly - I've been threatening to do it for months!
Dug this out of hibernation this afternoon thanks to a completely dry, sunny day.
By the time 50 miles worth of enjoyment was had, it wasn't so sunny anymore, but it stayed dry.
^^^ colour of the car looked very different in murky light conditions.
