Garage Clear out
Over the years I've collect a lot of stuff;
Polo MK2/MK3 Stuff
Left and Right reflex silver with Matt black line at the bottom parking dinks and some surface rust on top and bottom of door no main glass £20 each
Left burgundy good overall condition no main glass paint faded £40
Injection fuel tank surface rust no leaks £30
1 x Cylinder head from 1 liter engine £30
1 x Cylinder head from 1.3 GT liter engine £30
Pair of MK2 wings no indicator repeater not great condition top of one wing where it bolts in rust and need repairing bottom of wings need repairs £20 each
MK2/MK3 Rear beam £30
MK2 Front bumper black but has faded £20
Mk2 Saloon Rear Lights and bulb holders £40 for the pair
4 speed box £20
Polo Mk4
1.4 16v head £30
Misc
CBR 600 bike carbs not been on car need jetting £30
Was planning on doing a VR6 polo estate but life and plans change. I’m selling all the parts individual or together.
The plan was to rebuild one engine from the two. Was planning on doing a VR6 polo estate but life and plans change. I’m selling all the parts individual or together. The plan was to rebuild one engine from the two.
2x VR6 bottom end 2.8ltr AAA engine codes
1x was from running car which was knocking was believed to be bottom end on strip down the chain guide was gone Came from running Ibiza. Other was spare and not know.
3x Heads
3x inlet manifold (early metal ones can polish up nicely)
1x ECU and wiring loom OBD1 (Same as MK2 Golfs)
1x internal loom
All item are located in Birmingham (Marston Green/Sheldon)
Can take photos of individual items if needed.
£250 for all VR6 stuff
The list will be updated when I find stuff out the garage
Edited by residentmelon
Adding items
  • Replies 30
  • Views 2.4k
Have pair of leather seats came from a caddy need a tidy £20
I'm after the inside door handle surround. Not the trim, the bit the handle actually clips into. Black plastic with two locating dowels which the inside handle pivots on.
Do you have a drivers side for the mk2f?
Sent from my SM-G925F using Tapatalk
Will the caddy seat ls fit a mark 2?
Sent from my LG-D802 using Tapatalk
Hi mate,
im interested in the fuel tank, as the filler neck join has gone on mine.
could you send some photos of it?
cheers
Edited by Jb123
I will go through my box of plastic trim to check if i have one
I will check in my MK2 but i think the caddy is the same as the mk3 golf
45 minutes ago, Jb123 said:
Hi mate,
cheers
I will get pictures this weekend
It's this bit in the second picture I need for the drivers side, as you can see its broken at the bottom
postcode in brum ? gonna be over that way for the classic car show at NEC
and wondering if you're anywhere nearby
Not far at all 3 miles away from the NEC I will PM you postcode
I do have a box of bits from a MK2F
The little clip is on the elbow of a GT inlet I check if it on there
The fuel tank it's only surface i gave it a good scrub with the wire brush
Is the 1.3 head a mech or hydro head?
Have you still got the left mk2 door?
Still got the bike carbs?
I have 2 hydro heads
1 head is bog standard off a one litre
1 head is off a GT and i had the valves three angle grinded
1 is a mech head ona mk1 polo engine.
Yes i do
Yes i do
Update all VR6 parts have been sold
Inboxed you buddy
I still have loads of stuff to get rid of i'm in all weekend so if you need anything
Caddy seats still available?
Are the carbs in good nic? Any pics? Ill have 'em if they are pal. Sorry for the delayed reply!
1ltr head what year is it off please ?
No sorry the seats sold
The carbs are in good condition i bought them to do a conversion i took them apart to check the diaphragm then kept it all in a box i get a photo the weekend.
I have a hydro head which came from a 1992. i do have a mech head it's from a Mk1 Derby
