Wiring diagram
Hi all, does someone have access to a wiring diagram for a radio on a VW so I can check all the wires are correct as it seems as though my right front speaker goes from BLUE and BLUE/BROWN to RED and RED/BROWN
Thanks in advance
  • Views 1k
The wiring is as follows
LEFT
Pin 6 Brown/Blue to door disconnect pin 17 Brown/Blue to Speakers NEG
Pin 5 Blue to door disconnect pin 16 Blue to Speakers POS
Right
Pin 3 Red wire to door disconnect pin 16 then Blue wire to Speakers POS
Pin 4 Brown/Red wire to door disconnect pin 17 then Brown/Blue to Speakers NEG
Also I need to find a common ignition live, where can I find that?
The Ignition ON or "S" supply as VW call it ( 12v anytime the key is in the ignition switch in any position other than Start)  is Pin 4 of the Black connector Brown/Red wire
Do you have a picture of the ign switch
No picture of the switch, the "S" supply is marked as "SU" and has a the same Brown/Red 0.5mm wire
