G40 goodies - big list
Open to offers, collection from Leeds, can post
G40 Front Shock Inserts - Used - £10
G40 Cam & Pulley - 50
Polo G40 Inlet Manifolds x 3 - 35 each
G40 Stainless Exhaust, Copy of standard - 150
G40 Polo Mk2 Standard Intercooler - 125
G40 Polo Mk2 Standard Intercooler refurbed - 175
Polo G40 Servo - 20
Standard 1272cc PY Block unfortunately had suffered a melted piston, damage to 1 piston, scoring to a 2nd. - 100
G40 Head complete with std cam. mileage is around 170k. - 100
GT Head rebuilt with double-valve springs, sodium filled valves around 10k ago. - 100
Big valve head - 30mm/37mm - 400
PY engine block bored out to 77mm & honed. Painted red with crank and end covers - 200
Eaton M45 charger, pullies, belt, brackets & chip - 350
Jabba S1 charger fresh & rebuilt from OCD - 500
Jabba R1 charger serviced 8k ago with receipt - 500
Jabba S4 charger serviced approx 15k ago, no receipt :( - 350
Crane cams 268/268 cam - 175
Schrick 268/268 - 80 needs repair to dizzy end, has cracked
G40 Exhaust Manifolds - 20
Dewedged G40 Throttle Body - 70
G40 Looms - 100
G40 ecu's - 100
Jabba 65mm pulley & chip - 100
G40 clutch and pressure plate - 20
G40 ATV gearbox - 400
GT Inlet manifold - 50
G40 injectors - 30 for 4 or 10 each
GT injectors - 10 for 4
G40 TCA's - require new inner ARB bushes, ideal for g-ladersiete bushes. - 70
Mk3 TCA's with g ladersiete inner bushes and power flex poly outers- 70
1W build - £1000
1W diesel bottom end
1W engine block with oil squirters (+ 2 spare squirters)
Block has not been bored out to 77mm - expect £100 cost for this
1W crankshaft (low miles - no wear)
Accralite 1473 77mm forged pistons - (BNIB)
(Part no 9905 x77 -  Ring widths, 1.5mm/1.5mm/2.5mm)
Rods
Complete bearing set (brand new) (big end and main bearings)
Loads of gaskets including each end of the crank
Oil Pump
VAG water pump
Sump
  • Replies 16
  • Views 1.5k
  • grungeisdead
    grungeisdead
    drop me your phone number for whatsapp or email me at yousafn@gmail.com and I will send you a few pics buddy
More info on the g40 stainless exhaust please photo if possible. Thank you.
Long shot. Do you have number plate lense please for 2f coupe?
deal on the gt head g40 loom and ecu?
yeah man I can work something out, drop me a pm or email yousafn@gmail.com :)
at the moment no, but I am due to breaking a mk2f soon in red, so will let you know. maybe be a good few weeks tho
Hi I shall pm details now. :D
Hello mate have you had any interest in the eaton supercharger?
There is no price on the 1W block. What would you like for that?
Cheers Phil
Cheers Phil
Info and price below.
1W build - £1000
Rods
Oil Pump
VAG water pump
Sump
2 hours ago, c.w.pritchard said:
Long shot but do you have one of these?
i have a few of those plastic clips, if you can measure the diameter, i can make sure its the wrong one. no flying saucers I'm afraid, sold my last one the other week
hey up, fleeting interest but nothing concrete
 Really interested in your eaton supercharger for my g40 as I've been after one for a few years now.obviously with the run up to Christmas cash is always an issue.i have just under £300 saved for a rainy day is everything there ready to for the charger to my g40 and get it running as I'd really be interested mate?
Will measure the clip today. As you can see the bottom of the clip on mine has broken off. "Flying saucer" on my car is working fine thanks so it's not ready for a change. Many thanks.
Having major issues uploading photographs. Clip is about 3 cms internal diameter.
Edited by c.w.pritchard
