Mk2f 12v cigarette lighter port help
Hi am sure a few people have had this problem with the socket on the cigarette lighter on Mk2f.  When i try using the satnav the the plug does not fit very well and sometimes falls out,  how do I get over this problem?
Thank you.
Edited by 1vw2many
  • Views 855
i went onto ebay and bought a modern replacement and swapped that over , can get differant colours if you fancy a swap too
might be worth rewiring it too , i notice mine cant handle much as it shares the radio fuse , so i can either have sat nav or radio not both lol , if i could be bothered id wire it direct to the batt with a thicker cable and suitable fuse
Me and wires you forgot how long it took me to wire in radio on my other breadvan :-(
yeah just saying it would be an upgrade ....think its a fairly easy job to swap in a newer lighter socket
Ok I try a newer lighter socket 1st , any old one on ripoffbay will do ?
yeah pretty much universal i think ...pic one with a built in light if you want it to light up
was a long time ago now...i think i needed a dab of epoxy on the back side of mine to keep it steady
Ok shall see what I can buy :smile:.. Check out my other question :D
