6N2 suspension
I am going to lower my 6N2 polo but didn't know if I should get lowering springs or coilovers. I've heard that if I use lowering springs I will have to change the shock absorbers as well. Has anyone got any advice on what to go for? I'm not looking to spend to much and not too worried about the ride comfort. Thankyou
  • Views 857
If you're not wanting to spend a lot and the comfort isn't a concern then one of the budget kits for under £200 will most likely be the most suited option.
Damian @ DPM Performance
You don't have to change the shocks if you buy lowering springs unless they are knackered. Cheap coilovers are not worth it, in my opinion. It depends on your budget really.
