SPI (AAV) + GT + NZ parts.
Have a list of various AAV, GT and NZ parts, some have been cannibalised and others are complete and working.
Taken photos of everything, feel free to ask for more if you need to.
I don't have postage quotes for everything so I've just made some up as I went along to try and cover my costs. You're more than welcome to organise your own postage if you wish or to collect from Kent.
Paypal preferred.
AAV bits at the top, GT/NZ bits at the bottom.
AAV
 SPI rubber mount for throttlebody (New) - (£10 posted)
AAV ECU - £10 (£15 posted)
SPI manifold - £10 (£20 posted) Plastic wiring bracket is a bit broken but holds together fine with the top bit clipped on.
AAV cam + sprocket - £15 (£20 posted)
Fuel pump, no idea of age, used on my car up untill a month back - (£7 posted)
Used spark plugs and dizzy cap - (£5 posted)
Golf throttle body with AAV injector - £15 (£20 posted)
   I cut the golf and AAV cable wheels in half to make it work for the position of the throttle cable in the polo. Resolved the issue well. The throttle potentiometer has bits of plastic broken off where the screws got done up too tight (might be my fault that) I did have it working very well but you'd be better off taking your own potentiometer (presumably in better condition) and putting that on.
Throttlebody lower half - (£5 posted) Missing some bits that maybe in shed though, broken potentiometer and the throttle cable bracket is from the golf throttlebody.IMG_20161211_151207019.jpgIMG_20161211_151330796.jpg
Golf injetor, 1.8 - (£5 posted) Some bits missing too, might find them when clearing up shed though.
GT airbox 'adapted' to fit golf elbow + tube + Golf elbow - £20 (£25 posted) Also still have the section chopped out the airbox incase someone fancied making it a proper gt box againAUbWbYY.jpgIMG_20161211_151410647.jpgtmp_3290-IMG_20161211_151420608-460927128.jpg
SPI coil - £5 (£8 posted)
SPI Dizzy - £5 (£8 posted)
Nearly new dizzy cap - (£10 posted)
GT/NZ
Elbow and tube - £10 (£15 posted)
Air flow meter - £15 (£20 posted)
Manifold - £30 (£40 posted)
Maybe an injector rail to come but i think the injectors don't work for some reason.
NZ Throttle body £15 (£20 posted)
tmp_5620-IMG_20161211_180233864-1142497853.jpgtmp_5620-IMG_20161211_180106925-460927128.jpgtmp_5620-IMG_20161211_180127202768815569.jpg
Also have an ABD cam and sprocket £10 (£20 posted)
Might post a few more bits when I clean up the shed, GT injector rail mentioned above, NZ throttlebody, big dome air filter housing from the AAV.
Other items for sale:
H&R Springs Link to springs
Various lights for coupe facelift Link to lights
Edited by JoeUK
Editing
  • Views 943
Golf elbow + box sold
Does the Golf throttle with AAV injector make much difference in performance to a standard AAV SPI?
