2 faults on 6n2 tdi
Firstly I have an ABS fault and upon checking for errors it comes up with both rear sensors, is there a common problem with corrosion on the exciter rings
Secondly I have done a temporary repair with my speedo wiring where I have wired from the speedo sensor (gearbox) down to fuse 27/8 for engine management/immo can someone direct me as to where there may be a common earth or a common place where the wire breaks
Many thanks in advance
  • 5 months later...
  • Views 887
Bump
