Rear wiper
Hi guys need a little help.
The rear wiper on my 2004 9n does not touch the widow. Does anyone know what I can do to get it to sweep the window as it should?
Any ideas welcome
Sent from my SM-G935F using Tapatalk
  • Views 614
Hi, as with all wipers there is a spring on the underside of the arm , check that it is still there and that it is still appling tension to the blade. Work the arm back and to while giving a spray of wd or similar. Check the arm hasn't been bent also.
