Polo gti leveler
Does anyone know what i will neeed to remove from a gti for the headlight leveler? As im gona be getting all the stuff to put on my tdi but i need remove it myself, thanks in advance
  • Views 514
The sensor/connector/bracket/lever on the rear axle (passenger side) & the lighting dimmer control (as it has the blank where the original level control was)
What you mean about the light dimmer controler mate? And would i need the wiring aswell? Where does that run??
On the GTi the levelling sensor wiring will be part of the complete internal loom, when Matt01 & me retrofitted it on his TDi we just run new wires from the sensor to the old level knob and the K diagnostic wire to the radio connection.
On the standard setup, the surround by the main headlight switch has the dimmer control & the range control, but you will be deleting the range control knob, so you need the surround from the GTi otherwise you'll either have a redundant range control or a hole
Havs you got any pictures mate?  What you mean by the k diagnostic? Just trying to understand what i need mate as im gona be getting it all and removing it all saturday hopefully
No pics
To set the headlights up (alignment) you need to use VCDS to talk to the level sensor, to get it to give a car level signal then you adjust the headlight alignment, this is done via the K diagnostic wire and the easiest place to connect that was at the radio connector.
I havent got vcds mate or know anyone with it, do i need the headlight leveller? Or can they be set manually?
