6N2 GTI headlighta
Do i need the auto leveller for the headkights or can i run them without? And adjust them manually?
  • Replies 8
  • Views 748
To be strictly MOT legal you need the "auto level" system along with the headlight washers
So i only actually need them for mot? So it doesnt matter if i have them or not? Can you adjust them manually?
You could probably get away with just leaving the manual range adjust system, all depends on what your MOT tester is like ??
I know him very well so shouldnt be a problem so would it still worj with the headlight adjuster matee? As i really want them but dno if i can be arsed stripping a polo for some wires if i dont have to mate, ill be getting the washer jets and stuff so
The GTi lights will range adjust from the standard control by the light switch, tbh it wasn't a bad job to run the wires from the dash to the rear axle sensor
Have you got any pics mate?
You asked me that in your other post about the sensor :)
Sorry mate, forgot :) and will must have wait see cos ill be stripping car so just need know where everything is and pics of what i need bud
