Coupe gt. Water in passenger footwell
Help please.
Found a pond in the passenger footwell. Lifted the carpet and took out the under felt to dry out. Discovered the passenger door seal has split. Does anyone have a good quality used I can buy or point me in the right direction for new although I am aware that VW no longer make them?
Many thanks.
  • Views 798
also worth checking its not coming from the plastic membrane under the door card
the seal between the body and car , i guess you could find some universal stuff if you search rubber seal etc on google , old scirroccos use the same seal
Decided to buy 4 metres of universal seal form woolies at £3 a metre
Sent from my SM-G920F using Tapatalk
As a temporary fix super glue on clean rubber works really well.
