Faults, it has a few
Help. 2016 GTI Wouldn't even start at first. No lights on dash at all, but it turned over, fired for a second then stopped. Eventually after leaving it, it started but I've got all these faults, 11 in total. All the lights are working fine, so does this mean faulty sensor(s)?
  • Views 626
When you say that it wouldn't start, do you mean that the starter motor failed to turn over the engine, or that it turned over, but would not start?
If it is the former, it would pay to check your battery/starter connections, if necessary, charge the battery and once that you get it running, check that the charging voltage is around 14 volts.
All of the faults that you have listed could be attributed to low battery or charging voltage.
Welcome to the forum, by the way.
Regards
Edited by caretakerplus
To add welcome
