Best place to wire your earth cable from amp
Hi all I'm looking to get my amp set up in my polo 6n2 but I've heard alot about earthing issues does anybody know the best and easiest place to do it t.i.a
  • Views 931
  • CorbinOrchard
    CorbinOrchard
    There are a couple of places where you can earth a sub, if you go into your boot and peel back the carpet you can find a bolt where the tail lights are earthed too, I used this for a 400w amp, but if
There are a couple of places where you can earth a sub, if you go into your boot and peel back the carpet you can find a bolt where the tail lights are earthed too, I used this for a 400w amp, but if your like me and have a huge 1200w amp there is a hole further down where you can easily sand away the paint and put a bolt with an earthing bracket attatched (what I did).
Or you could just go to the seatbelt mounting brackets,
I would show pictures of how I did it but I sold my 6n2 over a year ago.
Hope this helps!!
Corbin,
Thanks corbin I will take a look tomorrow cheers mate I'm going to run a 1500w amp with a 1400w sub I use to have it set up in my old car so hoping it works in my 6n2
