6n2 what to look out for?
Bonjourno new member here from Skipton,
Work on the ambulances out of Bradford not the best of places haha no offence.
Ex soldier and absolute vw noob actually more of a bike guy than car.
So long story short my 4x4 impulse buy is costing me an arm and leg and I'm after a Runabout so to speak.
Do not need anything aesthetically amazing just a workhouse and a cheap un at that.
Budget is £500 and after looking down the 306,megane,206,Fabia route I settled I wanted an SDI due to the non turbo , reliability ( commute is mainly dual carriage way and no slip roads haha) I know about the acceleration is poorer than poor .
But I've found a polo which is a
6n2 I believe you call them basically an uplifted 2000 model .
150k on clock , serviced every 5k last two years , new Cambelt and steering pump 3k ago plus 4 new tyres .12months MOT and no advisory's past 3 MOTs.
Price is 325 which seems amazing value
Immaculate inside also
Only problem is passenger side down is dodgy got to lock from inside something about a bar.
No electric doors.
So question is this sounds to go to be true what should I be looking out for.....
  • Views 1k
First Welcome to the forum.
A 2000 could be a 6N2 or MK5 or 6N1 MK4 on this forum, easiest way to tell them apart is the speedo unit, if it has what looks like two separate units (speedo & tacho) it's a 6N2 but if they are all in one unit with the fuel & water temp at the top between the speedo & tacho then it's a 6N1
The biggest weak point on these is the gearbox,(both models) they are made of chocolate!! and there is a know problem with the pedal box ( 6N2 mainly), it cracks on the end by the clutch pedal, ( if get a good torch and get your head under by the pedals you can see if there are any signs of cracks/repairs) so make sure there are no nasty noises coming from the gearbox and no "creaking/groaning" when you depress the clutch pedal.
The passenger door lock will be the "paddle" that connects the key barrel to the lock assembly, £5 for a kit on ebay, Keep fit windows will also reduce your problems as the wiring from door to body are known to break and the window switches are frail (6N2 only)
The price is good, probably as it's got the least desirable engine ??
Thanks for the warm welcome Nige,
Yes the price is great , the guy seems also very genuine.
I believe it's the 6n2 from what I gather on the phone.
I will inspect the clutch thoroughly tomorrow when I'm going to view with intention to buy.
The guy has been servicing it GM oil mineral he stated every 5k .
I have synthetic at home as I use it on my bikes think it's 5w-40 is this okay to use.
Current car is gathering 18mpg so cannot wait I think the car will pay itself off in a matter of weeks.
Is it worth throwing redex though every 6 months
Well bought the car in question few little niggly points which I could do with some help
1.coolant never goes above 70c checked via obd and display on 6n2 , first line.
2.hand brake is a bigger , really high to get it on then you need to firmly press button in which I struggled intially
3.door lock pops out on outside
4.Crappy loose after market gear stick head (easily replaceable I gather)
That's it for now I think ...
Was stuck on road after putting handbrake on after buying , felt a right Pollock
In the future you really need to be asking these sort of questions in the "Technical section" that way you stand a better chance of getting answers :)
The diesels do tend to run on the cool side, I've just come from Birmingham to Milton Keynes and my 1.9tdi Octavia didn't get above 70c
Rear brakes, disc's or drums ? if drums the self-adjuster mechanism isn't the greatest and would probably benefit from a good coating of copperslip and then you might need to adjust or replace the cables
Door lock, there should be a torx screw that holds the handle into the door, above and outboard of the three main screws that hold the latch assembly in the door.
Standard Gearknob is a push fit, you just need to release the crimped on collar under the gaitor.
Engine oil 5W/40 synthetic to VW spec
Fantastic Nige yes I realised shortly after I posted this message.
Sorry :help:
