Wiring help Mk2f fuse 12
Hello my Mk2f keeps blowing its number 12 fuse and my inside light and radio won't work ??? What's going on people ??
  • Replies 8
  • Views 1.9k
Have you checked the wiring to the door light switch (in the chassis) and the wiring to the stereo? I think the fag adaptor shares the same fuse so start to have a rummage...
did you find out the problem as having the same problem ?/
hi mate,
still got the issue? leave fuse 12 empty
On 3/21/2017 at 00:51, Mk2f1998 said:
hi mate,
hah yeh do know what does it control??? radio ?
According to Mr Haynes Fuse 12 is for the Clock display in the speedo & the Brake lights
Hi mate,
Fuse 12 was very weird for me, if the fuse was out and was the engine was running i used to kill the engine. All the other components work absolutely fine on my car, Speedo, interior light, radio ect. It was like a kill switch for the engine.
4 hours ago, Mk2f1998 said:
Hi mate,
its so wired i found my problem with that i hadnt grounded the radio properly all sorted now though
Get a capless type bulb and attach a wire to each connector and put it across the fuse contacts then operate any suspect components and wiggle any suspect wiring etc. The bulb should only light when something is drawing current so if it randomly lights when say moving some wiring then there is the short. Saves on fuses.
