Polo mk2f breaking
Mk2 f polo for breaking most parts available
 1litre engine only done 30k miles
bumpers front and rear smoothed and painted gloss black instead of textured finish
  • Replies 8
  • Views 1.4k
You got pics of bumpers and rest of car please?
thanks.
Edited by koolspot
Hello mate the actual car has been sat outside under a cover but is quite damp inside so will need the seats cleaning and drying, carpets etc.
It won't let me upload pictures for some reason but if you've got Facebook I can pm you them?
Does the engine run ? how much please ?
Engine runs sweet and is still in the cars shell atm cambelt and water pump just been done also. Oil sump needs replacing as it weeps oil from common corrosion at bottom.
Id like to see £130 for engine.
Will have to take it out from shell unless you want to have a look whilst it's running.
PM sent.
Hi do you have the loom for this?
Do you have the plastic surround for the top of the filler neck?
Hi,
do you have the front wings and could you cut one of the rear quarters out?
kind regards
