Mk2 G40 Conversion Breaking :( Lots of parts available
Sadly, I'll be breaking my conversion. I started on a nut and bolt rebuild project a couple of years ago, but I'm not going to be able to fund it to the standard that I'm after. As a result, I'll be breaking it. The main parts of interest are priced as follows:
The first lot of parts are available for collection only (in Southampton):
Complete engine (1341cc PSD engine with forged pistons, big valve head and piper cam); comes with engine mounts and charger mounting bracket. Has less than 8k miles since its rebuild in 2004 and has had its oil changed every year, so less than 1000 miles between changes. Also, one of the oil feeds at the back of the cylinder head got damaged many years ago. PSD blanked this one off and T-pieced the remaining one so that both the oil pressure sensor and charger oil feed run off this now. Comes with PSD toothed belts. Cambelt and waterpump ware last changed in 2014 by John Mitchell Racing. Receipts to prove. £750
G40 charger. Rebuilt by G-Werks in 2009. Has only covered a couple of thousand miles since. The timing belt was replaced by John Mitchell Racing in 2014. Receipts to prove. I also have a spare set of oil seals that I can provide with this. £500.
PPP exhaust manifold; £350 Provisionally sold
PPP cat back exhaust; I cut the first 30-40cm off the front of this so that it could attach to my cat. I still have the cut-off piece, but would need welding back to the rest. £200
ATV gearbox; I've never used this, but it turns well by hand and selects the gears without issue. £300
8p gearbox; rebuilt by JP Race in 2005. Has only covered a few thousand miles since. Works well without issue. £100
PPP stage 2 subframe; unused and in as-new condition. £150
Polo GT charcoal interior; in good condition. There is a minor tear on the right hand side of the vinyl on the drivers seat and the cable that runs from the catch to the inside release catch has snapped (a common fault). Otherwise, the bolsters are in good shape and the fabric in good condition. £125
256mm brake setup; includes calipers, carriers, discs and pads. I can't vouch for the condition for the discs or pads, so you might want to replace these. £200
Rolling shell; I don't think there will be much interest in this as it needs a bit of money spent on it so I won't go into too much detail, but it comes with a G40 rear axle, Koni springs and shocks as well as VW Snowflake alloys. Except for that, it's pretty much stripped. Will need to be trailered. £50
The remaining parts can be collected or posted:
Helix organic clutch; again, about 8k miles on this. Good for big power! £100 + postage
GT inlet manifold and de-wedged throttle body with green injectors; I rounded off one of the bolt holes attaching the throttle body to the inlet manifold a few years back. It holds together nicely with the remaining 3 and not leaking boost. One of the injectors needs a replacement O-ring. £50 + postage
Strengthened driveshaft; Replaces the long one which is prone to snapping on high-powered cars. I bought this years ago and never fitted it. There's a bit of surface rust on it, but will wire brush off. £75
Mocal oil cooler and sandwich plate. £50
The engine, inlet manifold, gearbox and clutch are currently in one piece, so can be collected as a whole if anyone wants to make me an offer on a combined lot.
I have all kinds of other bits and pieces. If there's anything you need, just ask.
  • Replies 52
  • Views 8.4k
Would you post the driveshaft? Do you know if it is for an early or late gearbox?
Yeah, I could post this. I'll get an idea of postage over the weekend and let you know.
All I know is that they were from the run that Karl from PSD did many years back and I'd have thought they'd fit all G40's at the very least. Is there any info I can get for you such as measurements etc. that would help?
Pm'd for photos of parts :)
Well I'm assuming if you used it with an 8P it is for the early gearboxes.
I know there was a difference between early and late in regards to length but can't remember what off the top of my head. Regardless I can use it either way. Pm me a price posted and I'll give you money ASAP.
Ah, no. I never fitted it. I have an ATV box that it was going to go with. I'll figure out how much it will cost to post over the weekend and will drop you a line.
Are the seats still available - if so can I get a picture?
I'll have the driveshaft collected and pay cash to save hassle.  I'll pm you
Hi Jake, I didn't see your Pm; can you re-send please?
Yes, there is one other person who's interested in these as well. They are looking for pics also; I'll take some tonight or this weekend.
Edited by dabigginger
I can't edit the original post, so I've updated some of the descriptions and added photo's of most bits (and added a few more parts):
Complete engine (1341cc PSD engine with forged pistons, big valve head and piper cam comes with engine mounts and charger mounting bracket. Has less than 8k miles since its rebuild in 2004 and has had its oil changed every year, so less than 1000 miles between changes. Also, one of the oil feeds at the back of the cylinder head got damaged many years ago. PSD blanked this one off and T-pieced the remaining one so that both the oil pressure sensor and charger oil feed run off this now. I have an aftermarket oil pressure sensor fitted as I ran an oil pressure gauge. You might need to get a different one if connecting to the oil pressure warning light in the dash (and possibly a different T-piece). The washer on the rear engine mount has been pulled slightly out of shape and will need replacing. It might be an idea to fit 2 or 3 washers for extra strength. Comes with PSD toothed belts. Cambelt and waterpump ware last changed in 2014 by John Mitchell Racing. Receipts to prove the cambelt change. £750
G40 full blend charger Rebuilt by G-Werks in 2009. Has only covered a couple of thousand miles since. The timing belt was replaced by John Mitchell Racing in 2014. Receipts to prove the servicing (but not the full blend). I also have a spare set of oil seals that I can provide with this. £500.
DSCN2006.jpg.43acb085a1bf091712cb7320b74
PPP cat back exhaust I cut the first 30-40cm off the front of this so that it could attach to my cat. I still have the cut-off piece, but would need welding back to the rest. £200
ATV gearbox I've never used this, but it turns well by hand and selects the gears without issue. £300
8p gearbox Rebuilt by JP Race in 2005. Has only covered a few thousand miles since. Works well without issue. £100
Currently attached to engine - see above picture!
PPP stage 2 subframe Unused and in as-new condition. £150
256mm brake setup Includes calipers, carriers, discs and pads. I can't vouch for the condition for the discs or pads, so you might want to replace these. £200
Rolling shell I don't think there will be much interest in this as it needs a bit of money spent on it so I won't go into too much detail, but it comes with a G40 rear axle, Koni springs and shocks as well as VW Snowflake alloys. Except for that, it's pretty much stripped. Will need to be trailered. £50
PPP exhaust manifold £350 Provisionally sold
Polo GT charcoal interior In good condition. There is a minor tear on the right hand side of the vinyl on the drivers seat and the cable that runs from the catch to the inside release catch has snapped (a common fault). Otherwise, the bolsters are in good shape and the fabric in good condition. £125
Pictures to follow...
Strengthened driveshaft Replaces the long one which is prone to snapping. I bought this years ago and never fitted it. There's a bit of surface rust on it, but will wire brush off. £75 + postage
Mocal oil cooler and sandwich plate £50
G40 TCA's These are rose jointed and much more expensive than the standard Polo ones and getting hard to get hold of. These are brand new, unused and still in their wrapping. £200 + postage.
Lockheed remote servo kit This is a single circuit remote servo and should help with those Mk2 brakes! £50 + postage
Helix organic clutch Again, about 8k miles on this. Good for big power! £100 + postage
Currently attached to the engine, so no pictures at the moment.
GT inlet manifold and de-wedged throttle body with green injectors I rounded off one of the bolt holes attaching the throttle body to the inlet manifold a few years back. It holds together nicely with the remaining 3 and not leaking boost. One of the injectors needs a replacement O-ring. £50 + postage
Currently attached to the engine; see above pictures.
I have all kinds of other bits and pieces. If there's anything you need, just ask. Other bits will be added in the future.
ATV is still an early style gearbox I think so should be fine. No problem, look forward to hearing from you :)
Yes they are, here are some pics:
Sorry; I mis-typed the price for the stage 2 subframe. I'm looking for £175 for this.
Hello, do you have mirrors that are adjustable from the inside? If so are they still available?
Also interested in a few smaller bits if I could at it?
**Meant to say if I could have a look at it
I'm afraid the mirrors are provisionally sold. You're more than welcome to see what else I have. If you want to drop me a PM listing what you're after and when you'd like to come down, I can make sure it's all ready for you.
hi mate is the inlet manifold from the g40 still for sale? If so would this fit on my 1993 1.3 polo. Cheers
Still got the subframe mate?
I believe it would fit, but you may need to do other work to accommodate it. However, it's provisionally sold with the engine. Would you like me to let you know if it falls through?
It's been sold now, sorry.
Updated list:
Polo GT charcoal seats In good condition. There is a minor tear on the right hand side of the vinyl on the drivers seat and the cable that runs from the catch to the inside release catch has snapped (a common fault). Otherwise, the bolsters are in good shape and the fabric in good condition. £125
ATV gearbox I've never used this, but it turns well by hand and selects the gears without issue. £300 Sold
PPP stage 2 subframe Unused and in as-new condition. £175 Sold
Mk2 grille for single headlamps Brand new and unused, in perfect condition and with red piping £60
Mk2 front panel lower plastic trim Brand new and unused, in perfect condition and still in wrapping (2 available) £12
Mk2 front bumper Brand new and unused, plastic only, in perfect condition £40
Mk2 coupe rear bumper Brand new and unused, plastic and bumper bar, in perfect condition £60
Mk2 front bumper Reasonable condition £20
Mk2 coupe rear bumper Reasonable condition £20
PPP exhaust manifold £350 Sold
Strengthened driveshaft Replaces the long one which is prone to snapping. I bought this years ago and never fitted it. There's a bit of surface rust on it, but will wire brush off. £75 + postage Sold
G40 TCA's These are rose jointed and much more expensive than the standard Polo ones and getting hard to get hold of. These are brand new, unused and still in their wrapping. £175 + postage. Sold
Lockheed remote servo kit This is a single circuit remote servo and should help with those Mk2 brakes! Will need a one-way valve. £50 + postage
Fuel pump (lift pump) £30 + postage
Inline fuel pump £30 + postage
ECU with PSD chip £100 + postage
G40 wiring loom A few of the sensor connectors are missing the metal retaining clip, but otherwise fine £50 + postage
Blue temp sensor Brand new and unused £30 + postage
Front, lower brace bar £20 + postage
Rear, upper brace bar £20 + postage
Drive shafts with inner and outer CV joints £50 per side + postage
VW CV boot kit Brand new and unused £12 + postage
Speedo cable Brand new and unused £15 + postage
Speedo cable Fitted and used for no more than a few hundred miles £10 + postage
G40 Oil breather pod Brand new and unused £25 + postage
Brand new steering arms with new tie rod ends Brand new, completely unused steering arms with tie rod ends made by ZF Lemforder. They are the OEM manufacturer for a lot of cars, so will be good quality. £20 for O/S and £30 for N/S or £45 combined + postage
I'd consider splitting the engine, prices as follows:
I'd be willing to split the engine as follows:
Complete bottom end minus crankshaft pulley: £400
Big valve head with Pipe cam, thermostat, dizzy, plugs and leads: £350
PSD toothed belt kit + 2 belts: £175
Starter motor (nearly new): £60
Alternator: £25
Standard exhaust manifold: £25
I've also reduced the charger to £450.
Could you tells me weather you could cut me the steering rack mounts off the bulk head please, you can leave them on the bulk head and I'll drill all the spot welds out, I'm really really desperate
I'll take a look at what needs doing over the weekend...
