1980 Vs 2003 - VW2 Calipers
I'm trying to work out whether the VW2 calipers from 1980ish to 2003ish share the same disks and pads?
The reason is, my wife has a 2003 Lupo (same as a 9n brake wise?) and it needs disks and pads. I have a set of Brembo disks and Ferodo DS2500 pads that I used on my coupe when I upgraded to VW2's off a mk1 golf gti.
ECP and GSF have multiple options for both as I was trying to match up part numbers.
I know I could go try them on but it's not fun doing it outside in the dark so I'd rather only have to do it once!
  • Views 1.2k
From my research from the 6n onwards the discs width was reduced from 20mm to 18mm. But that is the only difference I can find.
That being said I bought the same Brembo discs I have fitted to the van for the 6n2 and the extra 2mm in width made no difference to the fitting.
Yeh I did see an option of 18mm which threw me off a bit, the disks aren't brand new so hopefully worn down a mm or two!
I was more worried about the disk offset changing for some reason.
Been searching for photos of pads fitted to newer cars, and they also have different shaped pads for inside/outside.
The 03 Lupo runs 239 x 18 discs on the 1.0/1.4 8v & 1.7 SDi  The 1.4 16v & 1.4TDi use 256 x 20 discs
It's a 1.4 16v Auto, but it has 13" wheels so must have 239mm?
This is the allocations Lupo Brake Allocation.doc  I put in Auto box but it didn't change the list ??
Thanks for the info, it's pretty obviously  different pads between the two.
Its as basic a model as it gets so hopefully it's got VW2's.
Tried it out today, doesn't work.
The pad attachment is different, the new ones clip on the the piston/ carrier, the old ones go on the the carrier with those spring clips.
The disks were the same diameter, but had a different offset and contacted the hub/ caliper carrier.
Was worth a try!
