polo 6n sunroof
Hello
I have a polo 6n, I put the car's sunroof Electric polo 6n1 this match properly,
But I do not know what wires to connect for this to work.
Thank you.
  • Views 2.3k
Hello
I plugged
the sun roof without a relay and it works it will be a problem ??
And is connected to just switch it wrong?
And if it is possible to get clear pictures,
Thank you very much for your help.
The relay and thermal fuse are there for safety
I put a fuse, but not composed Relay because I do not know what kind of relay should.
Thanks for the help
The relay is just a normal 4 pin 30 amp it's used to make sure the roof can only operate when the ignition is on, it energises to allow the Battery supply (30) via the thermal resettable fuse, to the roof switches
I realized thanks for the help
