Will 13x7 et10 wheels rub on my springs, mk2 saloon
hi looking to run 13x7 steels on my mk2 saloon , offset is et10 just wondered if anyone can tell me i theyd rub on the spring at all? thanks in advance
  • Views 886
They won't rub on the springs but if you are lowered you may rub on the arches.
I used willtheyfit.com as a starting point to getting some new wheels for mine. 5.5j 13" standard steels you've got roughly 20mm of inset to spare before you need to worry about them possibly rubbing on the struts. Then you just need to work out your arch gap and tyre size. Bear in mind under braking you'll lose some arch gap on the fronts.  Have a play, its strangely satisfying
Edited by nope
cheers for the help ,appreciate it
thanks for the help, appreciate it
