Newbie with some questions
Hi Guys
I posted here about four years ago when I first got my Polo (6n) and I'm hoping you can help with some general advice on behalf of my sister.
She's just bought her first car, a 2005 1.2 facelift model in black. Its a nice car, with about 91,000 miles and three previous owners. Cost her £846 which seems a good deal even if my dad had to travel from Brighton to Halifax to get it for her. She only passed her test a few weeks ago and her insurance came out at just over £1200.00 fully comp (with a black box) with Smart Wheels - my dads listed as a named driver but its her policy.
Anyway - we'd like some general advice on this model. Are there any things we need to aware of? Things that break, need upgrading etc. Tips on maintenance, great upgrades etc. One thing - tips on cleaning the roof lining would be great.
Any info would be lovely.
Thanks guys, appreciate your advice.
Fleur xx
  • Views 1.2k
Hi @Fleur,
Welcome back!
Bodywork on these cars is generally, good, however, due to their age, it is worth checking for rust, particularly on the sills and arches, and signs of poor accident repairs, as pattern body parts often are made from lower quality metal, or not as well rust proofed.
Electrics can be a weak spot on these cars. The wiring to the starter solenoid and the alternator load wiring is vulnerable to breaking down, particularly on diesels. A broken solenoid wire will result in the starter motor not engaging or running. A broken alternator load wire will result in the battery light not illuminating at all, and erratic charging voltages. These are both a relatively easy to repair using basic tools.
Power steering is electro-hydraulic, an electric pump drives a normal hydraulic power steering system when required.  Systems do not generally leak but the system is known to have several common faults, which really need diagnostic equipment to identify.
The wheel angle sensor sits at the bottom of the steering column, just above the rack, and can suffer from water ingress. Symptoms may include erratic power assistance to the steering, a fault light on the dashboard, or flickering headlights when the steering is applied. None of these symptoms are definitive of this fault. A replacement sensor is about £70, and access is reasonable with the car lifted and the driver's side front wheel removed.
I'm sure someone will come along and help with upgrades. Why not look in the projects area? Oh, and remember - general maintenance is key: full service, oil, plugs, oil filter, cambelt and water pump if it hasn't been done yet.
Hi Dean
Thanks so much for your reply. I'm going to make sure my dad reads all of it as a lot kinda went over my head!
Couple of questions for you.
1 - the car passed its MOT in January this year with three advisories,
suspension arm rubber bush deteriorated on both sides - is this an easy repair for my dad to do?
track rod end ball joint has slight play - again something my dad can fix?
exhaust has minor leak (front flex) - do I get whatever exhaust the garage recommends or is there a decent priced brand that I should have fitted?
2 - there was no owners manual with the car, when we turn the ignition key the oil light flashes orange about three times before going out. We checked the oil and its at the right level. Any idea why the oil light flashes? It doesn't do this on my Polo or in my parents Touran.
3 - Haynes manual - (my dad asked me to ask this question) he wants to know if this is the correct manual, he read somewhere that it didn't include info on the facelift model and wants to check if its Ok to get this one: https://haynes.com/en-gb/volkswagen/polo/2002-2009
The cars going to the garage next week for the exhaust to be fixed and we'll get them to put their diagnostic reader on it to check for any faults.
Thanks in advance
Fleur xx
4 hours ago, Fleur said:
Hi Dean
Thanks in advance
Fleur xx
I believe my above post covers the pre-facelift (9n) but some cross over to the 9n3 too. I'll see if someone can help with the electrics and give you some advice!
I would say the oil level sensor has failed, but this should show up when you get the fault codes read.
The Haynes manual does mainly cover the 9N1 but as there are few differences to the 9N3 90% of it are covered, there are no engine wiring diagrams included, if you want a full manual, you'd better off getting a copy of ElsaWin from ebay, it's a copy of the dealers manuals for all VAG models from 1995 to date
Thanks Nige - appreciate your help with the ElsaWin suggestion.
Found out the air box lid snorkel was broken off so my dad has just gaffer taped it up for the time being, looking for a second hand one. My dad reckons he can do the: suspension arm rubber bush deteriorated on both sides - is this an easy repair for my dad to do?
Where can he buy or borrow the kit to remove & replace the bushes?
Thanks guys
Fleur xx
