Window/central locking problem.
Hi Guys,
Hopefully one of you guys can help me out.
My sons 2001 6n2 1.4 Polo has developed a fault, He complained that the car was unlocking itself and winding down the windows while he was away from the car. I had a good search of the forums and saw that the usual culprits are either the door loom between the car and door or central locking pump. I've checked both and replaced the pump with one from a breakers, I have also changed the o/s window regulator,  switches and lock mechanism with micro switch.
The window fault only seems to happen now  when locking or unlocking the car. Am I correct in thinking that if the car does not have remote central locking that there is no convenience module as it's built into the drivers side window reg?
Fletch
  • Views 954
 Also check the tailgate wiring for the same problem. If it comes to it, cut the rubber with a sharp blade and repair again when finished. Not sure on polos if they have wiring both sides of the tailgate.
