Loom plug wiring for speedo unit mk2 polo help!!!
Hi All,
I am just wondering if somone can help me please as in a bit of a panic!
I have a mk2 polo ranger from 1990 pre facelift, for the past few years its had a tempermental issue with the power feed (I beleive its the live cable from the ignition feed) to the speedo unit as intermittently loose power to the instrument cluster and gauges every now and then it will flicker and mess about, I have pressed all the crimps down in the loom plug to try and make contact to the many cables and its been ok ish for a year but now it will just not work at all now. I am in a bit of a panic as I have mot coming up at end of May!
I do still have a working clock, full beam indicator on the cluster but I have lost temp,fuel gauges, handbrake light, oil & indicator lamp.
I dont know if there is a supplier of loom plugs or some place I could get one? I have had a look on ebay with no such luck or even if there is something like it that will fit ok?  The origional vw part number is: 321971998
Or is there a work around maybe I am open to ideas I dont care what has to be done as long as its working again to be honest.
Any help would be greatly appreciated!
Kindest Regards,
Lewis
  • Views 1.3k
Tried a Vw dealer or Vw heritage with that part number?
Wonder if the 3-pin voltage regulator on the back of the clocks is dying rather than the connections?
