280mm Discs
So my car went in for a disc change only for my mechanic to tell me the brakes are upgraded ones so he can't source the right part to do it. Bit of a win/loose situation but anyway, I now need to find some 280mm disc's for my 6n2 GTI. What car should I look at getting them from for them to go on my Polo? G60?
Found these, would they be right for me? (Sorry if Im not supposed to put links up like this)
http://www.ebay.co.uk/itm/Pagid-53950-Front-280mm-Vented-Brake-Disc-VW-CORRADO-1-8-G60-88-93-/231079444014?hash=item35cd687e2e:g:niYAAOSwm8VUyva4
http://www.ebay.co.uk/itm/VW-Passat-97-00-1-8-Syncro-EST-G60-158-Front-Brake-Pads-Discs-280mm-Vented-TRW-/122118800046?hash=item1c6ed902ae:g:AxUAAOSw8oFXzlpC
Also how hard is it to replace them myself to save it going into the garage again? its all been taken apart and put back together at the garage so won't have to worry about any seized bolts or anything like that luckily
Edited by rozza92
is your car 4 stud on the wheels if so yes corrado g60
pretty basic diy job to swap them
Try this company http://www.mtecbrakes.com/  great service and good products
Yes my car is a 4 stud so G60 its is. Would the pads be needed from the same car too? A previous owner did it so no idea what to get
should be yes
