Blue 1.0 5 door
Been looking to buy a 6n2 for a while for going to work.
Seen this on gumtree, 1.0 MPI, 33k, 5 door. Nothing fancy at all, manual windows, no central locking etc.
78F88512-28FE-4254-9E99-3CB305FF4E6A_zps
Took it for a test drive and everything seemed fine. On the 25 mile drive home as soon as I got over 50mph the drivers front wheel bearing had clearly gone!
So parked it up and had a look.
EE0623D3-EE17-4A06-AAED-3260F8897819_zps
B701A980-5E51-4527-960D-FCBAD2C855EB_zps
The sensible thing to do would be to just change the bearing, but the disks and pads were needing done, and the caliper bolts had already been rounded. So I went and picked up another polo. This time a rusty 1.4 16v colour concept with no MOT.
6C974BDA-4638-4D7F-8695-3D115CE5D39F_zps
4014D1A9-3614-4F80-8AA4-BC35681BF276_zps
ED7F3B7B-B42F-4C7E-9D73-0D1EF45C89A9_zps
Plan is to take all the good bits off this, with an upgrade to 256mm and separate hub/carrier.
Taking the blue one to bits.
4AF0E493-E009-4E6B-9C4B-3859C97A00A5_zps
Home made drive shaft pushing thing.
8EBE56E4-C67C-409C-A0FA-602C836DBFA5_zps
Wishbones and brakes off.
A9D29AE0-E50F-47EC-A8C7-1E45EC95026E_zps
Struts off.
6F68F660-18F1-4F76-8D46-503D587B2F72_zps
Threw some POR15 at them.
62931E90-B811-4114-A9A5-0953238352C5_zps
Brakes off the black one.
DDD8B443-A931-4136-A631-8C2ABE65F9DC_zps
Hubs off.
0E98BF0A-216C-4555-B721-59F5F0A32F33_zps
New wishbones fitted.
ED482948-8B49-4AB8-97F6-90459CB41924_zps
Hubs on.
2F592879-8E52-425B-93B0-0A33CF70F0CA_zps
Had a seized brake nipple.
F9E2F985-DA23-4111-99AD-69A18E7AFAF6_zps
And had a slider stuck in a carrier so picked up another from the scrappies.
13F17587-075C-4387-9962-3028C8BE4256_zps
Pistons were properly seized.
B466E6FF-0D63-400B-84C3-9B09BC82E0FD_zps
Pistons not looking too good, but still sealed.
7999FBD5-638A-475F-9DAC-C5B070181F9A_zps
Pretty much back together here. Just before bleeding the brakes.
DF6DBCA8-E430-4101-BF83-448496D1D14F_zps
There was a strange popping noise and a flat spot around 3k rpm, couldn't find any exhaust leaks so needs more investigating.
86551238-1C8B-4A76-95B8-5E1D9929C215_zps
Back together with the 14" wheels off the black one.
F0336213-0487-426C-AF0A-E646C8CDB3D7_zps
Running out of space for scrap...
581F2DD8-5836-4470-B29A-D0CB04F91E85_zps
Picked up rear disks and pads and a centre/ rear exhaust, but that's a job for another time. As well as fitting the interior ,CD player and electric windows.
A few bits of paint needing sorted and the obvious front bumper. But at least I now have a spare engine!
Edited by Ross36
Spelling...
  • Views 1.9k
Had a spare hour so got the seats out the black one.
Gave them a scrub with some soapy water, then treated them with stuff made for horsey saddles.
This was before cleaning.
34005792-A065-4F52-BAD4-713CF86A06DB_zps
Cleaned and fitted, think I'll keep the black door cards, it will be too much red otherwise.
7EF0D5D9-EE53-4FB6-A5D1-6772DEC03D85_zps
950B0C4F-08A3-4732-8446-D3AE6F07BA8F_zps
Still need to pull the wiring out the black one so for now they aren't heated.
Edited by Ross36
Great project I like the idea of buying a spare polo.
Nice - what are the head units in the black polo if I may ask? I am looking at picking up an OEM HU if possible.
The CD player will be going in the blue one,  There's a tape player in it just now.
