Newbo
Hi I'm James
Drive the new polo gti 17
Question for the admins... Could you specify make a forum section for specific MK polo's?? Save so much time with repeated questions
Thank you
  • Views 1.8k
  • nige8021
    nige8021
    The tag system has only recently been introduced, but will be the best way to search for model specific questions/posts but as it hasn't been in operation that long the results might be only a few pos
  • nige8021
    nige8021
    First Welcome to the forum.   If you want to make a build/progress thread about your car ? make a posting in this section https://www.clubpolo.co.uk/forums/forum/207-polos/  as you will see
  • Thank you   Any way of filtering the different topics to my specific model or do I use to the tag system to find something specific???
If you want to make a build/progress thread about your car ? make a posting in this section https://www.clubpolo.co.uk/forums/forum/207-polos/  as you will see this breaks the different models/years into Mk1~Mk9 But this is not the area to ask any technical questions, for those questions post in this section https://www.clubpolo.co.uk/forums/forum/213-technical-help-with-my-volkswagen-polo/  and as you will see these are broken down into different areas of the car and are not model specific
Thank you
The tag system has only recently been introduced, but will be the best way to search for model specific questions/posts but as it hasn't been in operation that long the results might be only a few posts especially on the newer models and as it's reliant on people who post to put the correct tags etc
Cheers guys!
