mk2f front wheel bearing replacment
I have play in my front wheel hub so I have removed the strut and have bearing out but have half the bearing left on the hub. I noticed Two lugs on the half of the bearing left on the hub so I have a two leg bearing puller but its not coming off. Advice and help please.
Do I need the new bearing pressing in ? or as manual describe bash it in with a metal bar :-(
  • Views 1.2k
http://www.ebay.co.uk/itm/K-Tool-International-KTI70382-Bearing-Seperator-Shipping-Included-/162518147580?hash=item25d6d621fc:g:vP8AAOSwYvFZGyia
bearing seperator can be had for cheap , or cut it with a grinder and chisel it off
some folk get away hammering them in , id try and see if a garage will press it in for a drink , or i use this kit that pulls it in with a threaded bar
http://www.ebay.co.uk/itm/23Pc-Front-Wheel-Drive-Bearing-Removal-Installation-Tool-Kit-UK-/201908763630?hash=item2f02b33bee:g:UtwAAOSw~bFWMyBT
I usually do what you've done then take my new bearing and the strut to a local garage and ask them to swap them over on the front pair of struts.
I went down the grinder route all good.  Thanks
