Jump to content
Retrospoke
88 Coupe S , Fast Road, Restoration
Recommended Posts
Retrospoke
Hey people,
Here's my new project :1988  MK2 Polo Coupe S
I've been kindly given the car from my house mate who recently had taken the car off the road due to a few issues.
- fuel tank leaks over half full ( new tank from vw heritage sitting here now)
- leaking radiator/ expansion tank ( new rad arrived last week )
-CV joint nearly exploded (replaced at the garage last week)
Lots of plans for the next few months it's got a fair bit of rust so that needs addressing before winter.
Edited by Retrospoke
  • Like 1
Share this post
Link to post
Share on other sites
heyholly__
My Coupe has the same problem with the leaking fuel tank, nightmare! Hoping to get it fixed though soon!
  • Like 1
Share this post
Link to post
Retrospoke
It's a expensive problem a leaky tank!
I'm striping the car for a good clean/ treating any rust along the way
radiator out today,
decided to do the heater matrix / thermostat at the same time due rusty mess I've found so far, so ordering those tonight.
Poped the expansion tank in the sink for a soak then got destraction by the air filter lid!
Grinder time!
After I made it bare metal, treated it we it with some k rust, a few times washing off with warm water/sand paper
Got a few coats if etch primer on, going to spray it bronze as I have a odd can left over
Spent rest of evening cleaning engine bay, not. Showing it yet , it's still filthy!
Share this post
Link to post
steveo3002
you know photobucket pics no longer work ?
  • Like 1
Share this post
Link to post
MartinB
Would like to see pics of this - suggest changing image hosting providers. IMGUR works for me and is pretty simple to use :)
  • Like 1
Share this post
Link to post
MartinB
Just managed to click on the links and take a look. I like it a lot and it's original as well!
I took a look at the MOT history online as well and there's previously been no mention of corrosion or rust, so I think whatever rust you can see must be surface only, which is lucky! The MOT has only just expired (May) so i'd be half tempted to pop in for a test and see what it fails on and that would be a good starter for 10.
Share this post
Link to post
Cymro
Have sent Retrospoke a Pm, hopefully he will be able to sort out the issue and use something other than Photofuckit.
Share this post
Link to post
Retrospoke
Above photo's are before I started .
Then I started on the air filter casing
Bare metal
Treatment ( the Rusty water below is what came out the radiator!)
Finished!
Damm photobucket I will take my images elswhere!
  • Like 2
Share this post
Link to post
Retrospoke
So the rads out, now I'm focusing on rust patches + cleaning everything!
Bonnet needs some work
Radiator housing is in a bad shape so I'm going to try and save it with some phosphoric acid.
  • Like 2
  • Love it 1
Share this post
Link to post
Elijah
Great project I had an f plate coupe s cracking motor.  Keep up the good work.
  • Like 1
Share this post
Link to post
Retrospoke
Traced the coolant leak to a warped and cracked thermostat housing,
New parts:
Thermostat housing + elbow,
Thermostat / O rings
Rocker cover gaskets
Engine earth leads X2
Carried out a coolant flush, as the Haynes manual stated using hose to reverse flush the system,
Share this post
Link to post
MartinB
Liking the work so far. Where did you get the earth straps from?
  • Like 1
Share this post
Link to post
Retrospoke
So I painted up the radiator fan housing, fitted the new thermostat/ housing , cleaned the air filter box, then poured in some coolant , then fired it up , bled out the air from the system, then waited for fan to kick in.
The tappets seem a little noisy , but it idled ok after a minute,  I've noticed the carb wobbles abit so I might need a new rubber gasket for the base as I suspect it has a air leak. But overall I'm happy I'm making progress as it's not leaking coolant anymore!
Ok next problem.......
My suspension top mounts on the front are extremely worn!
On the passenger side it's actually dented the bonnet!
It's covered 178k in its lifetime so let's hope they have been replaced at some point!
New bits:
Top mounts and rubber boots , ( Febi- bilsten) for front end
80 / 60 mm lowering springs ( which only cost giving my mate and his mum a lift to Stansted airport at 6am.... he used to have a bready)
The car doesn't seem to bounce around to much so I'm hoping the original shocks will do for now, famous last words?
Next week I'm getting the new fuel tank powder coated,
Rocker cover is also coming off for heat powdercoat
Going to order:
90 amp alternator as I hear you can fit a one from golf/Passat
Front ARB blocks
New fuel lines, filter,
Rubber Carb gasket
Spark plugs, dizzy cap + rotor arm
Strut braces
Underbody protection / paint for when I do suspension / fuel tank area
  • Like 1
Share this post
Link to post
Retrospoke
This week I've been doing a few little jobs,
Testing out some POR15 on some rusty bits,
Painted front bumper as it was so faded:
Removed a bodge on the rear exhaust ( shoelaces and wire ) with a pair rubber doughnuts.
Share this post
Link to post
Retrospoke
my shocks were a bit knackerd!
Splashed out ?
H+R cup kit
PPP Stage 2 Subframe
ARB Blocks
Febi bilsten lower arms
Febi bilsten track rods
Febi bilsten shock absorber dust covers/ boots
Front wheel bearings
Gearbox rubber mount + G60 rubber mount
Space at bottom of page
  • Like 1
Share this post
Link to post
Retrospoke
Finally got my tank and rocker cover back from the powder coaters but I'm really Happy with the results
fuel tank ( Porsche silver )
Stainless tank strap from eBay.de
rubber strip ( found on the side of the road )
Rocker cover color ( rootbeer )
Bolts done in black por15 paint
New rubber gaskets
Hubs cleaned then painted in hammerite
Brake covers were almost beyond repair but will do for now
Rocker cover fitted
Stage 2 Subframe fitted, ,( what a battle getting the ARB blocks on!)
Hubs, H,+R cup kit fitted,
Nearly there but held up with my brakes , somehow eurocar parts have sent me 1x  239mm disc and 1 X 263
Only fitted the correct 239mm one then got the other side and got angry!
Also my track rods are being stubborn so further investigations needed.
Hope to fit fuel tank then get a MOT this week/end
Share this post
Link to post
dvderlm
Looks amazing.
And pot luck bad luck from eurocarparts.
  • Like 1
Share this post
Link to post
dvderlm
Getting track rod ends off .. at the strut use a bearing splitter (mole grips, hacksaw, angle grinder when the cone is released but the nut just turns)  - take whole rods off at the rack then you need a vice and 2 long spanners, one holds still one moves away to release the lock nut... look carefully at the rod's thread for direction - I've even sought garage help with this for beer/biscuits.
Share this post
Link to post
Retrospoke
thankyou dvderlm,
I was going to go down that route as I have a big old record vice which keeps things in place,, but I have handed in the towel and given the car to the garage with the new trackrods,
still have a knock coming from somewhere so I am starting to think I need to replace both ends on the track rod arms, will check it out next week,
maybe these? if I start saving! :smile:
https://www.maxrpm.de/Steering-track-rod-for-all-Polo-86-and-86C-MK2/2F-with-track-adjustment-unibal-joints-Set-Left-Right-both-sites-adjustable
Share this post
Link to post
Duffy
Good progress
  • Like 1
Share this post
Link to post
kiran_182
Good little project, cleaning up quite well. Like the colour on the rocker cover
  • Like 1
Share this post
Link to post
dvderlm
Those trackrods... are you sure they fit RHD? ... I think the angles are different enough that you can't just swap sides.
Would mean you can get steering wheel dead straight on lowered car, especially with large spline column.
But more than I'd pay.
Knock might be the top mounts.
Edited by dvderlm
Share this post
Link to post
Retrospoke
good call didn't think of that!
Just looking at there description says they will modify them shorter for extreme lowering which is interesting
Would make sense its the top mounts, just changed them I guess they bed-in thus making  cup/nut loose
Share this post
Link to post
Retrospoke
Its nice to be back on the road in a old VW again!
Really Happy with the ride of the h+r cup kit + stage 2 Subframe /ARB blocks have transformed the handling.
After driving it for a few weeks I started to notice the carpet getting damp I knew it was rust around the battery tray but wasn't expecting a hole this big!
The battery bracket was hiding the worse  behind it, going to make a new one
New metal clamped in place, tried to make the patch as small as possible/ as resemble original, copying spot weld positions etc
Welding wasn't the best due to crappy access in this area but it will do, I have a classic mini so am quite used to welding in small spaces!
Spot welded Bracket , more primer then seam sealer both sides
  • Like 2
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
  • Similar Content
    • Jim1500
      By Jim1500
      Fischer c-box cassette holder in really reaIly good shape, no scrapes or damage. All red tags present and working. Insulation tape around prongs was just to prevent scraping centre console.
      I'll maybe even throw in a cassette of some retro driving music lol
      Postage shouldn't be more than £5 if needed.
      Cheers for looking 🙂
      Have listed on ebay so if anyone is interested please bid there thanks
      https://www.ebay.co.uk/itm/192689357967?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
      (Not sure if this is ok with mods please delete and apologies if this is a problem)
    • Jim1500
      By Jim1500
      Full set of MK3 wheel trims. Resprayed a good few years ago and paint cracking / peeling.  These are by no means mint. Fairly fresh scuff on last one in pic and some scuffs under paint, but could be sanded and painted again. All clips and rings present and they hold firm to the wheels. I had them on the car for a fair while without using cable ties.
      Postage would be around £7 I'm gauging if required can parcel up and send.
      Having a bit of a clear out and don't think these will be going back on my mk2 again.
      Cheers for looking, any questions please feel free to ask 🙂
    • Matty!
      By Matty!
      Salzmann Top Mounts:
      These have been fully greased and are in working condition, however the previous guy snapped a drill bit in the top so one of them could do with some modding, or something, I never got round to it. Plus I dont actually think they ever actually align, I think I got scammed on them TBH, hence why I didnt sell them on as I didn't want to move on the problem to another G40 Owner, however. If you want to take the punt they will work, just I havn't got the time to mess about with them as at the time I was rushing the car together for a Nurburgring trip, £60 delivered will get you something that is rare as fook and cool as fook.
    • Davemassey
      By Davemassey
      Evening guys and girls!
      ive not long got back from paying for my breadvan I won on eBay for the princely sun of £56! It's going to be a restoration project for me and my 6 year old son. She needs a fair bit of love after being stored in a barn for the past 10 years!
      Its due to be collected next weekend so I'll post some better pics when she arrives but here are a few from the eBay ad...
      look forward to picking your collective brains when the time comes and posting regular updates of what's been going on (may be a long resto as I'll be trying to "teach" my son along the way)
      but anyway...just thought I'd say hello!
