88 Coupe S , Fast Road, Restoration
Sprayed with some random paint I had on the shelf
Dirty fuel filter from only 90 miles traveled , looks like some sand from shot blasting and some chips of paint from powder coaters,
Hopefully this is most of it!
Edited by Retrospoke
Android glitch
  • Replies 32
  • Views 9.3k
  • Retrospoke
    Retrospoke
    So the rads out, now I'm focusing on rust patches + cleaning everything!   Bonnet needs some work Radiator housing is in a bad shape so I'm going to try and save it with
  • Retrospoke
    Retrospoke
    Above photo's are before I started . Then I started on the air filter casing Bare metal Treatment ( the Rusty water below is what came out the radiator!) Finished!
  • Its nice to be back on the road in a old VW again! Really Happy with the ride of the h+r cup kit + stage 2 Subframe /ARB blocks have transformed the handling. After driving it for a few
This week I've sorted bodged wing mirror out, the jubilee clip/ ducktape was a quick fix by the previous owner,
Got some mirrors on eBay, without the  internal adjustment wires , repainted the base plate due to lots of oxidisation/ corrosion, rebuilt, , will see if I can repair my adjustable version in the future but at least the car is safer to drive now
Great project I bet this would look good cleaned up and photo from distance.
You'll probably be able to put every drop of power down with those handling mods which would make it fun.
  • 4 months later...
I'm sitting here writing this post really missing the Coupe S,
its been in the garage for over 3 months now!
The mechanic doing the work is doing it around other jobs so its just not getting done, all is OK though as I have known him for years and he's oldschool and super cheap so don't care waiting, I recently moved house so the timing was right to give it to someone else to tinker with as I wouldn't have got much done myself with the move.
I was using it as a daily in Jan/ Feb it lasted about 400 miles before it started to show some new issues,
  • Pierburg started the classic over fuelling problem in the cold weather, started smelling really bad, and would sit around 2k on idle , then erratically loosing power / idle speed changing ( replaced rubber gasket was completly perished) not fixed
  • cleaned out carburettor followed guide on you tube,  no difference
  • compression test carried out ( cylinder 1/2 lower than 3/4 )+ mayonnaise in expansion tank (might have been me or owner before when it boiled over)  booked in to mate at garage ,
  • was unable to drive to garage had to be recovered😢 was also pulling more crap out of brand new tank so didn't want to run it anymore until flushed
Gave it to the mechanic and said just sort it!
  • Head has been removed, valves lapped/ cleaned was supper filthy from bad running + 160K , ( purchased Elring full gasket set so tappets will get new seals to)
  • one of the head bolts was corroded into block😡 fortunately after a month of soaking/ moaning😛 its out! !
  • found that the  head gasket had gone between water channels in block, also oil seal in corner was knackered and was one of my main oil leaks so happy this will be sorted to, as it was leaking oil onto alternator slowly, when its back I would like to upgrade to a 90 amp Golf MK3 ALT so didn't want to do all that work only to have it covered in oil again!
  • on last MOT it got a few advisory's on rear handbrake  / brake line corrosion so have given mechanic some FEBI cables / told him to rebuild drums / look into brake lines , tempted to get some good-ridges/ snazzy ones all round if needed
So fingers crossed it comes home soon I'm itching to take it for a spin! / would be good to get to a meet before the end of the year,
last photo after giving it mega clean/ clay, was off the road at this point + making a mess of the drive #toldoff😢jqWfTMG.jpg
images didn't work
Well done for keeping it going.
Nice job on it, keep motivation !
  • 8 months later...
Sadly going to be sticking this up for sale as it never left the garage it went into work for
any body that is interested please let me know will need to be collected on trailer from kelvedon Essex  :(
Hi,
 I know that it's short notice, but I'll be in the area tomorrow and was wondering if I could come and take a look at your Polo to see the extent of the engine work that's been done and what's still left to do. I'm guessing that it's one of the cylinder head bolts that's corroded in the block? As I have repaired these before. I won't be on the forum over the weekend so if you wouldn't mind dropping me a text and I'll call you.
My number is 07774513617.
Regards, Dale.
