Garaged since 1994 ...
Hello ClubPolo,
Today I have signed up to your forum hoping for some advice i.e. what best to do with a pre-loved Polo…
We have what I believe to be a Mark 1 Polo N in our garage. It has been there since Jan 1994, where we put it pending changing one of the rear lights prior to getting new MOT. We never got around to it, which sounds stupid, as it was in otherwise more or less a roadworthy condition at the time; it had been driven regularly to that date, clocking up 79,000 miles.
1.       I have the registration document that gives the date of registration 30/6/81 and tells me it is a Polo N.
2.       I have last MOT certificate that shows MOT until 26/11/93.
3.       Engine originally fitted was 895cc. But the latest MOT certificate states engine as 1050cc. I don’t have any service records; so don’t know if and when engine was replaced.
4.       Battery – the battery has been removed at some point, so I’m not yet able to say whether or not the car will start.
All advice and suggestions welcome.
I can see from one of the other threads that you might like some photos, so I'll try to get some at the weekend and post them here next week.
Many thanks,
Kay from Wembley
  • Views 973
  • Before you connect up the battery and try starting it, take out all the spark plugs and slowly turn the engine over on the big nut on the crankshaft pulley, as if the cambelt has snapped or lost it's
Pictures help but really a good service and clean up is all that needs to be done
Thanks for your encouragement Kiran. I was afraid that all the working parts might have seized up through lack of care and attention and that I might have to send it to scrap. I'm sure at least it will look better with the years of grime cleaned off it. Then I'll take some photos...
K
I wouldn't scrap due to the engine being seized up. engines can be rescued or swapped out.
if the body is in good condition some one will save it on here get some pictures up and sell as a rolling shell.
Before you connect up the battery and try starting it, take out all the spark plugs and slowly turn the engine over on the big nut on the crankshaft pulley, as if the cambelt has snapped or lost it's teeth, spinning it over on the starter motor could cause the valves and pistons to become intimate causing quite a few ££'s of damage
