drivers seat has loads of play
hey guys, my mk2 bread van drivers seat has loads of play, any way to make it solid again? it squeaks mad amounts
they fit on the legs ...if theres no movement at the base then i doubt its them
i would suggest you pop the side covers off and  check both hinge /catches are in good order ...its only a pivot on a pin so not much to go wrong , seen them crack if a fatty owned the car before lol
My driver side seat is missing the bolt which holds the plastic cover on the pin in place, you dont know where i could find one do you?
can you put up a picture
