1.3 mk2 polo saloon fuel lines
Hi,
I've recently bought another mk2 saloon and has a leak on the fuel tank. I have bought a replacement tank and I'm looking to replace all the fuel lines. I use the car as a daily so got no chance of taking it off the road to check what fuel lines ill need. Does anyone know of a kit you can buy that has all the correct fuel lines ill need or does anyone know what size fuel lines ill need and how much of each size?
  • Views 612
theres no kit available ...you would keep the hard plastic lines and replace the rubber bits each end , 6 &8mm as far as i know
