Mk2f In Tank Fuel Lift Pump
Hi All,
I've converted my Mk2f to a 6n2 1.6 16v ARC engine, Therefore I have changed the fuel pump to a 3 bar pump.
So my question is is there away to do away with the lift pump, make it so the external pump will just suck the fuel threw it or is there no need because it wont restrict the flow?
I'm pretty sure I've seen a thread before talking about how to make the lift pump redundant or so the external pump will just pull it threw.. But can't seem to find it..
Cheers for any help in advance..
  • Views 941
Use the lift pump to fill a swirl pot near high pressure pump?
Even under heaviest acceleration  you won't empty a 1 litre swirl pot and you won't maintain top speed on road for any lengthy period.
